Rear Speaker Installation (96-00 Civic Coupe)
Thanks to Solid_Snake for this DIY!
Do this on your own risk, this process is a little time consuming, IIRC all the bolts are 10mm
tools-
rachet, several extensions, 10mm socket, phillips screwdriver, flathead screwdriver (not in pic)
1.
2. Loosen the bolt with the 10mm socket, i recommend using several extensions so you have more space to move the rachet around
3. After removing the bolt, raise the seat cushion as shown, don't forget the seat belt buckles
then at the bottom of the cushion you'll see hooks at the left and right of the cushion:
4. now that you have removed the cushion, you'll see a pocket in the side panels:
inside each pocket there is a phillips screw, unscrew that.
5. fold the rear seat backs
6. Remove the bolts holding the seatbacks to the bracket
well you can't remove completely the seatbacks, but by doing the previous step will make the seatbacks mive easily, so you can access the pivot
7. remove the pivot bracket bolt (IIRC it is a 14mm bolt)
the pivot bolt construction: pivot bolt-->washer-->bushing-->toothed lock washer (this is for the driver's side bolt, the passenger side is the same order, just instead of going to the right of the bolt, those parts go to the left of the bolt)
8.
9. Now pull the side panels towards the front of the car, be careful not to crack any of the plastic peices
now your interior should look something like this:
10. remove the top mount stop light bulb by turning the socket counter clockwise
Now follow steps #3 thru the last one in the sedan DIY ( I'm too lazy to retype everything, LOL):
https://www.hondacivicforum.com/m_136218/tm.htm
Installation is the reverse of the removal procedure. If you have any questions PM Solid_Snake.
tools-
1.
8.
cowsgonemadd3
02-20-2008 06:30 PM
Patrick
Audio/Video & Electronics DIYs
12-13-2005 10:00 AM
