01 civic stock stereo removal, help needed
My CD player quit in my 01 EX, I ordered a used replacement - will I have to worry about re-programming? I could also use some direction in removing the Stereo as well as the rear speakers. Thanks, Ed
RE: 01 civic stock stereo removal, help needed
http://www.metraonline.com/_assets/m...NST99-7899.pdf
see if this helps for the deck install.....the rear speakers....thats a different story.
it is real ez. the back speakers are a HUGE pain to get to. The trim is hard to remove and so is the deck it is a huge pain and you have to be careful not to break anything or loose clips. for the stereo you have to take out the little cubby hole / sig lighter molding by pulling it then disconnecting it. then there are two 8mm bolts under the stereo. they pry the whole ac/stereo molding out with a small screwdriver. there are a few bolts holding the stereo in. I believe 1 or 2 are tight and you might need a 90 degree screwdriver and or a set of plires and a screwdriver head. It is pretty easy.
