2007 SI Stock Sub
Old 08-10-2007, 12:58 PM
trutudat's Avatar
Default 2007 SI Stock Sub
Anyone know what the stock sub is for the SI sedan has and how many watts it is?
Old 08-23-2007, 10:46 AM
Default RE: 2007 SI Stock Sub
i believe it is 2 6.5inch..............they say 7 inch.
it has a built in crossover. i can only think it is the 360 watt.
hope this helps.
Old 08-23-2007, 11:54 AM
JD 2007's Avatar
Member
The stock Si stereo is 350 watts max. Thats for all the speakers. It has 4 speakers and 2 tweeters up front. And a sub. The amp is 5 channels and probably puts out 25rms clean x 4 and 75rms clean to the sub. This is continuous rms, not max. The max is 50 watts x 4 for the 4-6.5" speakers and 150 watts max to the sub, thats 350 watts MAX. Not RMS continuous.
Old 08-25-2007, 03:35 PM
i know of the door panel speakers and the rear deck speaker and sub, but there is supposed to be seven speakers total in the 06 and ups. where are the other two located?
Old 08-27-2007, 02:26 PM
JD 2007's Avatar
Member
7 speakers. 4-6.5" woofers, 2 in the front doors, 2 in the rear deck. 2 tweeters in the dash and an 8" subwoofer equals 7 total. 350 watts total MAX/PEAK. About 150-175 watts rms total to all 5 channels. This is just a very close guess, NOT a fact.
Old 08-27-2007, 06:42 PM
how in the world do you replace the tweeters in the dash? if i am not mistaken, they are right where the door and the windsheld meet?
Old 08-28-2007, 04:49 AM
JD 2007's Avatar
Member
Its definately possible. But no need to replace. When you replace the stock front door speakers, which DON'T have a tweeter in them, your adding another set of tweeters. If you were to replace all 4-6.5" front and rear speakers, then you would have 6 tweeters. Or a total of 11 speakers.
Old 08-28-2007, 06:17 PM
thanks for the info. i forgot that the door speakers didn't have tweeters. I guess the separate tweeters in the dash are used for vocals. yeah it prolly would be expensive to replace every single speaker.
windcalmer
08-04-2007 01:30 AM
Polygamy16
05-03-2006 09:15 AM
PhatCivic01
03-06-2006 12:34 AM
PhatCivic01
03-06-2006 12:34 AM
Quick Reply: 2007 SI Stock Sub
