Intermittent speaker and tweeter buzz, driver door - HondaCivicForum.com
Reply
Old 04-07-2017, 12:07 PM
Default Intermittent speaker and tweeter buzz, driver door
Hello everybody
(2000 Em1, EX, D16y8)
About 6 months ago I installed a touchscreen stereo headunit with a built in amp 50watt RMS per channel, with 4 channels.
within the last two days, I've been getting an intermittent buzzing noise from the driver door. At first I thought it was the vent or something, but I put my ear to the tweeter and it was loud and clear.
the pattern is about 10 seconds of loud buzz, then 20 seconds off. And it repeats this consistently, although there are sometimes when the frequency of buzz changes a little bit.
I discovered:
-the car does not need to be running
- the stereo needs to have some volume, if it is muted there is no noise, but past 1 volume click the buzz is no longer affected by stereo volume.
-no aux cord is plugged in
-no phone charger in plugged in
now for the weird part, today it was driving me crazy so I took my door panel off, and unplugged the tweeter, and the buzz noise moved from there into the main door speaker. Then I unplugged the main door speaker and it appeared in the right side main door speaker!! I feel like I could chase it through the entire car
additional info:
I usually have a steady scratchy sound through all my speakers that behaves the same way but that's ignoranble because it's consistent and relatively quiet, and the same in all speakers.
please help its super annoying! I cannot listen to music without ripping my hair out!!! Thank you
Old 04-11-2017, 12:52 PM
Quote:
Originally Posted by Jack Murphy View Post
Hello everybody
I discovered:
additional info:
it sounds like you have some distortion emitting Front the deck. Have you ever turned up any of the output settings?
Reply
Thread Thread Starter Forum Replies Last Post
97 civic intermittent driver window tldudley Mechanical Problems & Technical Chat 0 02-21-2012 09:53 AM
Tweeter and antenna question [email protected] General Civic Talk 9 03-05-2010 12:40 PM
FM Radio Buzz jjbaker Audio/Visual & Electronics 2 09-05-2009 03:40 PM
Speaker size and new speaker suggestions cowsgonemadd3 Audio/Visual & Electronics 10 02-20-2008 06:30 PM
annoying buzz/rattle at 2500 rpm jsebski Mechanical Problems & Technical Chat 6 09-18-2007 03:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
