problems with my 2001 Civic odometer 888888 and gauges
Old 07-19-2010, 09:22 AM
vivicho's Avatar
Default problems with my 2001 Civic odometer 888888 and gauges
Hi,
I have a problem with my gauge cluster. I read a lot about it but I couldnt find an answer yet. Sometimes the odometer shows TRIP AB 8888888 and sometimes everything works fine. Also all the gauges sometimes just die meaning that everything marks 0. Temp, gas RPM and Speedometer..
All the lights in dash work fine.
I have noticed that when the problem occurs (usually when put the ignition) the battery light blinks intermintently so I think that it could a grounding issue.
However I have cleaned almost all the contacts under the dash and checked the wiring.
I think that It could be any conector under the hood.
Any advice will be helpful.. I am really tired of been dealing with that problem.
thanks
Old 07-19-2010, 10:55 AM
Have your alternator tested.
Old 09-16-2010, 04:33 PM
OHCivic's Avatar
Default Had the exact same problem
I ended up replacing the instrument cluster with one from a Junk Yard.
Only problem I have now is the new Cluster Mileage reads way higher than my last one.
I am not sure if you can reset the mileage or if the PCM has an auto configure that will load the correct Mileage. Any ideas on that would be great.
Old 10-11-2010, 04:11 PM
mach1racer's Avatar
I think you can take it to the dealer and they can set it for you.
Old 12-30-2010, 06:57 AM
FORT342's Avatar
You may call up some dealers and see if they can reprogram it for you, which if they can do, I'm sure they won't do for a small fee . Otherwise, you can always keep checking eBay or recycle yards for used clusters and find one that most closely matches yours for mileage...
Old 04-24-2015, 12:49 PM
eltaber's Avatar
Default resolder contact points.
Originally Posted by vivicho
Hi,
thanks
The contact solder points in your instrument cluster are loose, you need to remove your cluster remove the white plastic cover and resolder the 12 conector points that are by the wire harness plugs.
Old 04-24-2015, 11:12 PM
itburnswhenIP's Avatar
check thread dates bofore you post its 5 years old.
KLK99CIVIC
09-05-2010 05:14 PM
OHCivic
02-07-2010 06:43 PM
swimerskidude15
06-05-2007 06:09 AM
bmxchickie
06-04-2007 09:58 PM
jbum
09-23-2006 10:39 PM
Quick Reply: problems with my 2001 Civic odometer 888888 and gauges
