got my 115V plugs installed.
Just installed 2 115v plugs in my car, i used a 300w inverter with 10Ga wire connected to the battery, the inverter is under the center console at the very front.
Here's the pics, i never thoguht to take install pics... sorry
http://www.cardomain.com/ride/3049153/4
This is where the inverter is, behind the plastic
Pics of the plugs and switch to disable/reset the plugs
Another pic of the plugs
And a pic fromt eh passenger's point of view, showing that the switch is pretty much not visible from that angle.
RE: got my 115V plugs installed.
ORIGINAL: chunkbird
That is such a good idea! Looks sweet too - not a hack job. Good job, what are you going to use the plugs for other than just to have?
I'm sure you could have put those anywhere. I actually plan to put switches in those spots for my fire department lights on my Civic of the same year.
Do you have any pictures of the 'in process' like with everything apart? It looks awesome all done I'd love to see how you did it!
EDIT:
Just re read your original post, sorry it's late. So i see you have no in process pictures. So my question is how difficult is it to remove that console?
EDIT:
ORIGINAL: monkeydude3
EDIT:
EDIT:
But basically it's really simple, pop off the shifter surround peice, just held on with clips
unscre the 2 screws for the cig lighter panel, pop that off, bunch more clips
pull out the 2 clips at the front neaar your feet (as seen in my first picture) these clips will probably break, but it's no big deal, they're not necessary
there are 2 screws near the shifter that you need to take out
then there's the 1 screw in the center console
and 4 more screws on the back sides of the console on the outside, usually hidden by the seats
pop out the ebrake cover thing (just a tiny piece that makes toomf or the ebrake to come through the plastic) make sure the ebrake is on, lift up and back, done
That may not be entirely accurate, i am just going by memory and this was 2 weeks ago
