Stereo woes
Old 10-26-2004, 02:09 AM
NorCalRice's Avatar
Default Stereo woes
I bought a harness to wire up my cd player into my 94 civic, everything is wired properly, but the unit won't power up. When I plug the stereo into the car(with the ignition off) I can hear the cd player power up a small motor (I think, that's what it sounds like), but when I turn the ignition switch, nothing happens........
Fuses are good, and I'm out of ideas. Anyone have any input????
Old 10-26-2004, 07:42 PM
Default RE: Stereo woes
you might have a short somewhere.
Old 10-26-2004, 08:35 PM
sacicons's Avatar
where are you in norcal?
Old 10-27-2004, 01:43 AM
NorCalRice's Avatar
It's more like Central CA, really. I'm in Cambria, which everyone associates us with Southern CA, but down south isn't my cup of tea, so I stick to the North.
The thing about the stereo is, when I plug the stock tape player back in, it works fine. Damn.
Old 10-27-2004, 10:14 AM
I remember I had the same problem with mine but it was so long ago I can't remember what I did to fix it. Are u 100% sure that the unit is good and what brand is it. Do u know how to use a multimiter to check for continuity.
I would definatly check if u connected the ground and +12V right. I would definatly check ground insert one lead of multimiter into ground of wiring harnes and another one touch any metal that is grounded. You should have continuity.
Old 10-30-2004, 11:55 PM
Default [Deleted]
[Deleted by Admins]
perkelp
06-29-2007 12:01 PM
cowsgonemadd3
04-05-2007 05:32 AM
awoconsequence
03-01-2006 09:22 AM
perkelp
03-22-2005 06:17 PM
RAM672
11-08-2004 11:22 PM
Quick Reply: Stereo woes
