We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Honda Civic Forum Home - Honda Civic Classifieds - Civic Photo Galleries - Create an Account
Go Back   HondaCivicForum.com > Civic Style > Audio/Visual & Electronics
Sign in using an external account
Register Forgot Password?
Search
Welcome to the HondaCivicForum.com.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 10-19-2006, 09:53 AM
FlipHKD720's Avatar
Send a message via AIM to FlipHKD720
Default Subwoofer Under Back Seat
Has anyone ever put a subwoofer under their back seat? It would save ALOT of space, but im not sure whats under the back seat. I've lifted my cushion up and looked under it and i just see its metal under there, but whats under that? Is it possible to put a sub under there? I think i could figure out the wiring and stuff, but is there thingsi cant mess with underneath the metal under the back seat? Anyone ever tried/done this?
__________________
Old 10-19-2006, 10:08 AM
Default RE: Subwoofer Under Back Seat
im pretty sure thats the gas tank so don't be drillin before u find out.. cause i know the wire that is in there is for the fuel pump. i don't think its possible why don't u build on in the spare tire well and counter sink it so u can but a board over it to put things on top..
__________________
19 inchs and 10 switchs........
Old 10-19-2006, 10:29 AM
mxs's Avatar
mxs mxs is offline
that's definitely your fuel tank.
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 10-19-2006, 10:52 AM
amg6975's Avatar
Yeah, it's perfect though... just use your gas tank as a box. It's already ported and everything, just open your gas cap. Then you can get a fuel cell and put it in your trunk. Wait, then space saving is gone... do it anyways.
__________________
Old 10-20-2006, 01:19 PM
FlipHKD720's Avatar
lol alright well does anyone know how the quality of the the sound with the in-floor subwoofer such at this http://www.hondacivicforum.com/m_208570/tm.htm is compared to a fairly normal subwoofer set-up such as mine right now: http://www.hondacivicforum.com/photo...Type=6&apage=1
__________________
Old 10-20-2006, 01:36 PM
amg6975's Avatar
You could always just get an Infinity Basslink II if you're hurting for space.
__________________
Old 10-20-2006, 03:08 PM
1997 Chevrolet C/K 1500
My Garage
my only issue with doing a spare tire box is the sub firing direction.... firing any sub upwards will give you maximum trunk rattling with less bass.LOL
if ya dont wanna take up much space then id say buy smaller sub or subs that use small box space...
if ya do 2 10s heres an idea...
pull your trunk carpet out on the sides and build a box to go as far back as posible and build the box kinda like a triangle shape so the subs would fire back inwards and towards the front.. kinda like my side panels i built... BUT they would be the whole box and just angle it back as far as you can at that angle....
Click the image to open in full size.
they are only slightly angled....
something like that....
i think thiers quite a bit of room for a nice box for a 10s one on each side.
that would use the least ammount of space...
you could even notch the one side braces and be able to make the box alittle larger... JUST be sure to brace the metal around the uncut pieces OR when you build the box you could also just use some angle iron around the side of the box and screw the angle iron to the side panels... which would brace the steel as good as stock and also brace the box so it wont move as well you would also want to brace the box to the floor as well.... then just carpet the boxes to somewhat match and then you got yourself 2 nice boxs....... tucked away leaving you lots of space in the trunk and also still alowing you to keep your spare tire where its at
what ya think?
i just came up with the idea.LOL
tho my sub need to much room to do that.LOL
tho a 10inch sub on each side would be realy nice! depending on what model subs you get of course....
__________________
once again civic-less. but its better to have bills paid off than a extra vehicle.
till the next project civic i get- thank you and goodbye. i will return.
^supersize, thanks
Old 10-20-2006, 09:52 PM
That sub in the spare tire comp looks cool........but wait till a gallon of milk goes flying around and lands right on top of that sub
__________________
98 Civic DX Coupe
Old 10-22-2006, 02:35 PM
FlipHKD720's Avatar
Quote:
ORIGINAL: jimijam
lol i know. But i think if you put another piece of plywood on top of the sub (with a hole in cut in it of course), the sub would be sunk into it, and then you could put a grill over that.
Yeah addiction thats a good idea, i only have one 12" and i like it, so idk what im gonna do. I got an idea though [8D] The box i have used to be for 2 10"s. This is what it looks like on the inside: Click the image to open in full size.
As you can tell from the drawing my box is divided into two sections. (One for each 10") I covered the left side hole with my amp and just made the right side hole bigger to fit my 12" in and used the same box. I'm thinking if i just cut off the whole left side of the box right where the divider is, I'd still have the same size box as before and i could just mount my amp on the back of the box where nobody could see it. That way i could pull my back seats down and put big stuff in the trunk still.
__________________
Old 10-25-2006, 10:50 PM
Send a message via AIM to cbr600rr2469 Send a message via Yahoo to cbr600rr2469
Here is what I did in my 92 dx doesn't move at all and still have plenty of room in the trunk
[IMG]local://upfiles/13146/17091453EDF44056B1DCF56F33BCD22C.jpg[/IMG]
Reply
Tags
back, backseat, car, civic, civics, countersink, floor, honda, mount, place, put, seat, spare, subs, subwoofer, subwoofers, tire, underneath
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Go-Part
K&N Engineering
Advertise Here
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaCivicforum.com content, comments, or advertising. HondaCivicforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaCivicforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
