Power Steering Fluid Level
Hi just a quick simple question.
I've just bought a S/H Honda Civic 2003 Insprire S VTEC, standard UK spec.
Normally, on a car with power steering, I would expect to see a steering fluid reservoir and I would check the level in this regularly. However, on mine, there does not seem to be such a reservoir. Although the manual does mention that the power steering fluid level should be checked regularly, it does not say how to check it or where to look.
Any ideas?
Thanks
Mark
Any ideas?
Thanks
Mark
RE: Power Steering Fluid Level
If your Vtec's the same as mine, On the right hand side of the engine is a cylinder about the size of a tin can with a small filler cap on top, just next to the windshield washer reservoir, that's the poiwer steering fluid, should only need topping up at service unless you get a steering problem.
Thanks - I will have another look.
However, I received this reply from a Honda dealer.
"Your Civic is fitted with electric power steering, as such is driven off the vehicles electrical system. Therefore does not require fluid."
I don't know much about anything to do with car mechanics to be honest, but this sounds wrong to me...
Mark
Mark
bmarcinczyk14@yahoo.com
10-21-2013 04:52 PM
skyline83
01-23-2011 01:51 PM
prodigyskate5
01-21-2009 01:13 PM
