Drivetrain DIYs Anything that involves the performance of the vehicle.
DIY Oil Sandwich Plate Install
Old 10-24-2010, 06:44 AM
Default DIY Oil Sandwich Plate Install
1. Why would you want to do this?
To be able to install an Oil temp and/or pressure sensor. To be able to install an oil feed line for a turbo system.
2. How long does this take?
~1 hour, taking your time.
3. Precautions?
Nothing really. If you just drove the car recently, then the oil will be hot. Wait about 2 hours for the oil to cool completely.
4. What's needed?
Oil Sandwich Plate
Oil Sandwich Plate center bolt
Replacement oil filter
Replacement oil
Any applicable oil gauges or oil lines
5. Tools needed:
17mm wrench to remove oil drain bolt.
Oil filter wrench (not necessary, but helps if the oil filter is on too tight)
Oil drain pan
Socket wrench, or torque wrench
Jack
2 jack stands
Step 1 - Removing Oil filter
Jack up vehicle. Always use jack stands.
Crawl under vehicle and remove oil drain plug to allow oil to drain into pan. Re-install oil drain plug once all oil has been drained.
Locate Oil filter on your vehicle and remove.
Step 2 - Prepping Oil Sandwich Plate
Install any and all sensor senders or oil lines onto the Oil sandwich plate prior to installing plate onto the engine. I have installed an Oil temp sensor here.
Be sure to tighten all parts of the Sandwich Plate prior to installing.
Choose the correct adaptor by threading the female end onto your engine. If two or more of the adaptors fit onto the engine, thread the adaptors into the oil filter to determine which adaptor is to be used.
Step 3 - Installing Oil Sandwich Plate
Slip Oil Sandwich Plate onto the engine. Be sure to have the rubber O-ring on the sandwich plate against the engine.
Slide center bolt through the middle of the Oil Sandwich Plate and thread onto the engine. Be sure to move wiring or oil lines as needed.
Torque center bolt to 30 ft lbs. If a torque wrench is not available, may sure the center bolt is nice and tight.
Install replacement oil filter onto center bolt and tighten.
Fill engine with replacement oil. Start vehicle and check for leaks.
If leaks are present, remove oil sandwich plate and confirm that everything has been installed correctly.
Step 4 - Maintaining your Oil Sandwich Plate
With every oil change, be sure to re-torque the Oil Sandwich Plate center bolt as removing the oil filter may loosen it over time. Again, if no torque wrench is available, make sure the center bolt is tight.
madjoker14
04-15-2009 04:22 PM
bcrichguitars
08-20-2008 06:09 PM
madjoker14
08-02-2008 05:28 PM
oilltd
06-10-2008 04:06 PM
noshowallgo
10-06-2007 11:54 PM
Quick Reply: DIY Oil Sandwich Plate Install
