IACV & ECU Re-pin
Old 08-22-2007, 11:17 AM
asdfbrendan's Avatar
Default IACV & ECU Re-pin
Recently converted my 98 HX CVT to manual. Replaced CVT ECU w/ manual ECU. As a result, pinning for IACV different. A/T uses 3-pin IACV plug and M/T uses a 2-pin (right?). Based on the article I read (link below), my understanding is that I need to replace 3-pin MAP sensor with a 2-pin MAP sensor and 2-pin IACV plug. Then I have to re-pin the ECU as well. The article says you will only need 2 of the 3 wires.
If that's the case, can't I simply disconnect the 3rd unused wire, keep the current 3-wire plug and re-pin the ECU? The ECU I'm using is a P2N for a manual HX.
Car is currently idling high (around 1500 rpm). My understanding is that the solution mentioned above is the appropriate fix.
http://i208.photobucket.com/albums/b...iring.9698.jpg
Any input would be greatly appreciated...Thanks!
jlor010
08-08-2010 06:21 AM
jamisonh
02-21-2009 10:17 AM
muuurph
11-17-2008 10:54 AM
turbob18c1
04-07-2006 07:34 PM
97civicturbo
04-11-2005 02:27 PM
Quick Reply: IACV & ECU Re-pin
