Help "92" 5-speed civic want start
Old 01-24-2009, 11:19 AM
HoNdAboi09's Avatar
Default Help "92" 5-speed civic want start
I was driving on the highway and my car jus turned off, I pulled over to the side of the road and tryed to restart it, but it would'nt start so i left it there over night, when i came back the next morning it started up fine but.... when i drove it it felt like it was going to turn off, I drove it for about 5-miles to my exit where i took it to the shop. They then told me thet my alarm was shorting out the fuel pump so i replaced fuel pump and got a keyless entry installed , plus i changed out the fuel filter cause i thought it might be clogged someone please help i aslo heard that it might be my main relay. Tell Me What You Think
Old 01-24-2009, 11:40 AM
Is the dash CEL ON?
When you turn the key to ON(II), listen carefully for the low humming noise of the fuel pump priming for 2 seconds. If it doesn't prime, check for a blown fuse 31 under the hood and a blown fuse 18 under the dash. If those are fine, then replace the main relay.
Have you checked for spark at the plugs?
christinav09
05-29-2010 07:59 PM
KP1972
03-18-2010 04:19 PM
inthezoneac
12-27-2008 11:17 AM
Papo
09-18-2008 07:08 AM
logeoff
08-18-2008 10:23 AM
Quick Reply: Help "92" 5-speed civic want start
