MSD IGNITION question
96 civic ex
i dont plan on installing the msd ignition right now. far as im concerned, i dont need it yet. it was at a good price so i got it...
NEWAY. i cannot seem to find anything as to all that is needed to install it. from what ive found, i need an msd distributor cap and a harness. and the msd distributor cap has aspot in which the ignition coil, in the ignition box, is connected to, thru a wire...i think. do i have to buy a new distributor too? any suggestion plz
i've used the search thing and the explorer itself and nothing is helping....
RE: MSD IGNITION question
I'm not sure what you are asking, what exactly did you buy? You need an external coil, the ignition box, either a kit to modify your stock cap or an already modified cap for msd external coils, 8.5mm wires aren't a bad idea either. You keep the stock distributer.
http://overspeedmotorsports.com/images/pn6320.gif
just the box.
see, thats the stuff i needed to know. thx.i seriously took time in searching. i do have have msd wires 8.5mm.
i did a lil bit more lookin and added 2 n 2 together.i'd put a different cap thatwires into an external coil. that coil wires into the ignition box...
just the box.
96, 97, aftermarket, box, civic, d16y8, distributor, egnition, honda, ignition, install, msd, sci, wiring, wwwoverspeedmotorsportscom
