ground wires give you HP gains? WTF? - HondaCivicForum.com
Reply
LinkBack Thread Tools Search this Thread
Old 05-27-2005, 12:00 AM
Default ground wires give you HP gains? WTF?
i was just at ebay, and i found a few sellers selling ground wire kits like <THIS> that claim a 5-8 increase in hp. huh? i understand having a better ground makes your electrical system more reliable, but i've never heard of anyone getting gains off of it.
is this true or just a gimmick?
Old 05-27-2005, 12:42 AM
Default RE: ground wires give you HP gains? WTF?
Gimmick. Supposedly a better ground allows for a better spark from the spark plug, but even if it did, I'm sure it would only be noticable on a very heavily tuned car with a lot of power.
Old 05-27-2005, 01:14 AM
Why on earth would you believe an eBay sellers description of the gains of an automotive product? Better ground wires will make your car idle smoother and your lights won't dim out. Save some money and just clean your grounds. Take some sandpaper and sand them down until they look new again.
Old 05-27-2005, 04:23 AM
actually grounding systems are dyno proven, but its totally dependant on the grounding points you select. I have seen with my own eyes a 6 whp gain (friends V8 Stang), and a few on magazines of 3 and 5 hp gains to the wheel. Its also in the most current issue of import tuner if you dont believe me.
Old 05-27-2005, 06:41 AM
I'm selling some "Grade A Select" Air for you to use in your tires, you'll see a noticable 5-6HP gain. Quantities are limited.
Old 05-27-2005, 07:32 PM
what about the Nology wires with the ground straps on them they have dyno prove gains over standard aftermarket wires with no ground......
Old 05-27-2005, 07:46 PM
The Nology wires aren't ground wires. They're spark plug wires with a built in capacitor (just happens to need a ground strap for the capacitor).
Old 05-27-2005, 07:49 PM
See above......clutchjunkie is asking about ground wire kits, not ignition wires.
Old 05-27-2005, 08:56 PM
if you have a poor ground system. then of course its going to lose a little power from the ignition system. but if that was the case you would have a check engine light for a misfire.
Old 05-27-2005, 10:22 PM
Not that I am an expert but people pay 100's on plug wires, it's the same electrical system so...?
Reply
Thread Thread Starter Forum Replies Last Post
B16A2 w/ ITR cams - what gains will an aftermarket header/IM give? Captain_Sl0w Header, Intake, & Exhaust 2 07-23-2008 07:55 PM
Going to have to give this a WTF GReddy_Civic General Civic Talk 3 06-07-2007 05:01 AM
voltage stabilizer and ground wires outlaw2049 ECU Tuning & Fuel Management 10 04-28-2006 11:10 AM
ground wires smokingemcee Engine & Internal 4 05-01-2005 02:34 PM
ground wires smokingemcee Engine & Internal 2 05-01-2005 03:08 AM
Tags
1996, 22, 300zx, civic, cx, forum, fuel, gain, gains, ground, honda, horsepower, hp, increase, rail, straps, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
