help!!!!!!! seat belt alarm will not stop
Old 11-11-2007, 10:23 PM
90civicoldskool's Avatar
Default help!!!!!!! seat belt alarm will not stop
its an honda civic si 90 my seatbelt alarm will not stop beeping, i need help, cant drive with this like this, should i find the fuse and rip it out? cut out the speaker? buy an part? need help thanks
Old 11-12-2007, 03:43 AM
Default RE: help!!!!!!! seat belt alarm will not stop
put your seatbelt on...problem solved
Old 11-12-2007, 04:55 AM
Fiirkan's Avatar
ORIGINAL: Forty04
ZING!
Old 11-12-2007, 05:42 AM
lol, no even when the seatbelt is on or in!!! thats funny, sorry didnt think to add that!
help!!!!thank you. i did look at the wire diagrams in an repair manual, maybe all just cut the wire.
Old 11-12-2007, 07:28 AM
oh, haha! Well, I guess its probably a bad sensor or something. Dig around under there and see if anything is obviously disconnected/brokeen/etc
Old 11-12-2007, 07:48 AM
Mr Mobsta Man's Avatar
Look under your seat and find the wire connected to it. Make sure it is connected. I'm not sure that is it though becaue I think if it is disconnected then it will not beep wheater or not your seatbelt is on or not so if it is plugged in then unplugg it and the beeping should stop.
Old 11-12-2007, 07:33 PM
thanks ill try it and get back to u. didnt think about that, u guy are great
Old 11-15-2007, 11:53 AM
Littlehag's Avatar
most likely the wire that mobsta man is talking about is shorted to ground, causing the seat belt alarm to be on at all times (when ign. is on). insulation could be worn somewhere...
disconnecting it might work, and might not, depends on where the short to ground is.
Old 11-26-2007, 07:36 PM
rmnz116's Avatar
My 90 civic DX was doing that... it turned out that my wire was shorted... check it out...
Old 09-27-2013, 02:14 PM
LERX909's Avatar
hey man im having the same problem, where is that wire located?
Quick Reply: help!!!!!!! seat belt alarm will not stop
