How Do I reset the ECU?
Old 09-24-2005, 10:15 AM
Auto98EX's Avatar
Default How Do I reset the ECU?
I've gotten some different answers on whether or not you should reset the ECU after an intake install. Well maybe it isn't necessary, but I figure it can't hurt, so can anyone tell me the easiest/fastest way to reset the ECU on my 98 EX?
Old 09-24-2005, 01:48 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: How Do I reset the ECU?
Easiest - take the negative off of the battery for like 30 minutes...not the fastest though. I heard it can be done much faster with some sort of a fuse.
Old 09-25-2005, 12:35 PM
mill$civic's Avatar
i dont think you have to reset it, the ecu jsut makes the proper adjusments..but ya i heard the battey thing works
Old 09-25-2005, 01:20 PM
fast93civic's Avatar
ok,
yea take the negative terminal off the battery for at least 5 minutes, then reconnect it back, start the car up and let idle til normal operating range, dont tap the gas or any thing like that, then shut the car off, and then its ready to use whenever.
Old 09-25-2005, 01:41 PM
97CivicEX's Avatar
There is no real need to reset the ECU. It is constantly adjusting and learning. Depending on what you do or where the current ECU seetings are set, you can be making it longer time for the ECU to completely learn the new settings. However it is not a big deal. If it makes you feel better to reset it, do as suggested by others.
mrtimepa
06-20-2013 08:33 AM
05BlueEX
05-15-2006 07:53 PM
bak0707
05-09-2006 03:40 PM
Toonz
01-24-2006 07:22 PM
civicfan87
10-08-2005 09:40 PM
Quick Reply: How Do I reset the ECU?
