I HAVE NO AIR!!!!! NOT COLD OR HOT!!! NOTHING!!!PLS HELP!!!
Hi again!![sm=violent053.gif]
Hey I recently lost my AC[sm=badbadbad.gif]. I have no air at all.I guess is a fan that goes inside under the glove compartment, I changed the blue and brown relays that are located there.
An dirent work, I think that it migth be a resistence or something little.
If you had experiences like this please share..[&:][sm=ts.gif][sm=shootshoot.gif]
[sm=signs003.gif].
[sm=signs003.gif].
RE: I HAVE NO AIR!!!!! NOT COLD OR HOT!!! NOTHING!!!PLS HELP!!!
Find the blower motor. Check the resistance. If the resistance in really high then most likely your blower motor is burned out. Also make sure all the wiring to the blower motor is fine.
it is probably clogged. take off the hoses that your coolent go into the car and blow in one with water and watch old coolent come out the other side. also try it the toher way around.
it sounds like a bad blower motor. it doesn't sound like a clogged heater core. he said he wasn't getting any air (hot or cold). usually with a clogged heater core you'd just get cold or lukewarm air. and quite possibly a wet passenger side floor board.
Couchpotato226
09-22-2014 01:24 PM
Jackdigsdirt
06-13-2011 05:57 PM
general23cmp
12-20-2008 10:43 PM
dregular
02-09-2007 09:37 AM
