Injector Cleaner
Old 06-21-2006, 11:00 AM
FlipHKD720's Avatar
Default Injector Cleaner
I was a local auto shop today and i saw something i'd never seen before. It was an injector cleaner, a bottle you pour into an almost empty gas tank, fill up your gas tank, and dont fill up again until the whole tank is gone. Its supposed to clean out dirty/clogged injectors. Has anyone heard of this, used it, or know if it really works?
Old 06-21-2006, 11:44 AM
riceburner700's Avatar
Default RE: Injector Cleaner
same thing as like sea foam.... i used some 30 dollar can i cant remember the name but after words like a week later my injectors started to tick and has never stopped...
heard sea foam is excellent, i would try some but im expect some brand new rc 310cc's in the mail either today or tomorrow...
Old 06-21-2006, 12:26 PM
FlipHKD720's Avatar
whats sea foam?
Old 06-21-2006, 12:50 PM
sea foam is great.
http://www.seafoamsales.com/motorTuneUpConsumer.htm
Old 06-21-2006, 01:57 PM
FlipHKD720's Avatar
so can i use Sea Foam myself? Just liek pour some into the gas tank and run it through?
Old 06-21-2006, 02:13 PM
the right way to clean injectors is to remove them and clean them. that way its not sitting in the tank eating away at plastic and rubber parts. it can also free up some shmeg and clog your injectors.
Old 06-22-2006, 10:26 AM
ORIGINAL: FlipHKD720
Follow the link above. Gas Tank, Crank Case, and through the IM is the way to do it
Old 06-22-2006, 12:00 PM
civicexracer's Avatar
Old 06-22-2006, 03:07 PM
D16z6's Avatar
Another thing similar to Seafoam is ChemTool which you can get a Wal Mart. It does the samething like sea foam does you can either pour it in the gas tank or the crank case.
Old 06-23-2006, 09:26 AM
FlipHKD720's Avatar
In that SeaFoam write it up, she used 1/3 of a bottle. Does it matter how much you use in your crankcase and gas tank?
Quick Reply: Injector Cleaner
