ED-EF Swaps 1991 and older Civics, CRXs
b18c motor swap to 89 hatch
Old 12-03-2008, 08:10 AM
absente's Avatar
Exclamation b18c motor swap to 89 hatch
ok to start off i am tj and i have an 89 hatchback civic si that i am looking to put a b18c motor in. i have looked all around the forums and i believe this is the best route for me to take. i have some experience in mechanic work but i really havent ever dropped a motor in a car before. should i have this professionally done or not. i have also read on some forums that if i use this motor that i will need to cut into the firewall so that the intake fits. my car is a si model with the multiport fuel injection, so am i really gona have to cut into the firewall and could i use the stock si intake with the b18c ecu or is it a different intake all together.
i found the swap and i believe the kit has everything i need but the mounts and a cable/hydrulic conversion kit. how much will these two things run me.
also the motor swap kit is around $4K, does this seem right or am i about to be ripped off.
how much should this complete swap run me when everything is done.
Thanks for the help,
TJ
Old 12-03-2008, 08:17 AM
absente's Avatar
Exclamation by the way here is the motor swap that i am looking at
http://www.japanmotorimport.com/inve...er_details.php
Old 12-03-2008, 10:30 AM
ltkenbo's Avatar
Well I know those engines go for around $4000 at least. As far an the intake goes, I'm not exactly sure, but AEM and maybe some others make "hybrid" intakes to fit into swapped engines.
Old 12-04-2008, 12:10 PM
munkeewrench23's Avatar
you should be ok just need to get the aftermarket motor mounts and the hybrid intake which are also sold...however if this is not your only car i would take the time to do the work yourself it will be a great learning experience for you...
Old 12-04-2008, 02:25 PM
absente's Avatar
Default thanks guys
you guys are a lot of help, thanks.
Old 04-10-2009, 07:20 AM
absente's Avatar
Default the motor mounts
does anyone know where i can find the motor mounts and the clutch conversion kit at. i have been low on cash and unable to fix up my car and i am now getin ready to start on it.
93b18civic
02-14-2011 01:57 PM
legal
01-26-2008 09:35 PM
roc_sky
02-26-2006 07:45 PM
cdiddym
12-01-2005 07:11 PM
drtalon
18
08-19-2005 12:21 PM
Quick Reply: b18c motor swap to 89 hatch
