EG Swaps 1992-1995 Civics
short block D16z6 with D15b7 head???
Old 10-02-2011, 10:20 AM
susy76's Avatar
Default short block D16z6 with D15b7 head???
I don't want to Change the look of the engine,but I need to Know if I can use a Short block D16z6 with my D15b7 head? I don't want a fast car I only want a little more power without change a original look.
Old 10-02-2011, 12:36 PM
stoochy's Avatar
Well you would make less power with that set up, as the D16z6 is a vtec based engine and the D15b7 is not so less power. Usually you would put a d16 head on a d15 block to create a "mini-me" swap. Just curious what was wrong with the original engine?
Old 10-02-2011, 06:08 PM
susy76's Avatar
Well, the original engine run ok, the only problem is burning oil, smoke a little bit, the engine have a 177,000 miles and I try to increase a little bit more power
Old 10-03-2011, 05:42 AM
Do you have a d16z6 currently in your car and you want to swap heads, or do you have a d15b7 currently in your car and you want to swap bottom ends?
Regardless, it will work, but I am just asking.
Old 10-03-2011, 01:26 PM
susy76's Avatar
I have a d15b7 currently in my car and I want to swap bottom ends and keep up the same head, I don't want to Change the look of the engine
Old 10-03-2011, 01:49 PM
Gotcha. You might get a little more power from the swap, however, not much I am sure. Again, the swap is possible and all current parts on your car are interchangeable with the D16z6 block.
Let us know if you have any other questions.
Old 10-03-2011, 07:26 PM
susy76's Avatar
Thanks Bro, My Idea is to use the D16z6 block, put New rod and pistons with more compression ratio (may be 10.0:1) and use my D15B7 Head, ported head and polish Valve
Lambo Civic
03-23-2012 05:42 AM
mpklkj
12-22-2011 03:35 AM
candyman420
06-06-2009 08:32 AM
jo7man4
01-27-2007 01:13 PM
BillyB98
08-17-2006 05:06 PM
Quick Reply: short block D16z6 with D15b7 head???
