1997 Honda Civic Ex temp gauge needle doesn't move
Old 03-24-2012, 07:32 AM
97Ej8's Avatar
Default 1997 Honda Civic Ex temp gauge needle doesn't move
I just got my Ex to start running yesterday. When I was driving it I noticed the temp gauge wasn't moving at all. Or rather just alittle above the line from cold. Is that bad?
Old 03-24-2012, 08:13 AM
switch263's Avatar
That's a rather vague question. Have you checked coolant levels? How long did you let it run for? Need more info if anyone is going to help...
It could be low on coolant (which would manifest in overheating if left running long enough, usually, from my experience), a stuck thermostat, a bad gauge, any number of things.
Old 03-26-2012, 05:38 AM
97Ej8's Avatar
The coolant levels are good they're full. How would I check to see if it's a stuck thermo stay? Also the gauge does move but just alittle above the cold line. That's it. But the car isn't over heating
Old 03-26-2012, 05:56 AM
axis11's Avatar
Check if you have any thermostat at all. The previous owner might have removed it.. Its a common trick people do before selling a car that has cooling system problems.
Old 03-26-2012, 06:29 AM
Does the heat in the car work?
If yes, the temp needle on the cluster is damaged, or the sensor/wire is damaged.
If no, then check for a thermostat. Might as well just replace it ($10 part) while you are in there.
vXc760
09-17-2012 07:05 PM
ChristianL
04-20-2012 10:15 AM
siwel177
12
07-17-2009 06:47 AM
fastfrankie
07-08-2007 11:28 AM
4D4GCIVIC
12-26-2005 11:36 AM
Quick Reply: 1997 Honda Civic Ex temp gauge needle doesn't move
