95 1.5 sohc 16v i need info
Old 02-26-2006, 08:42 PM
88civicjordan's Avatar
Default 95 1.5 sohc 16v i need info
i just bought a new honda civic 1988 with a 1995 1.5 liter moter in it it is my first honda so i need help. the motor seems pepy so should i keep it and upgrade it or put in a new moter if a new motor is needed what will fit? i also need specs for my 1.5
Old 02-26-2006, 09:01 PM
Nail I3unny's Avatar
Default RE: 95 1.5 sohc 16v i need info
is it vtec? it sounds like a d15b7 but that doesnt sound right if you say its peppy. from what ive heard the b7 is slow.
Old 02-26-2006, 09:20 PM
it is a d15 b7 but you hane to remember this is my first honda so it might be slow in comparison to other moters 5 spd helps it. any sugestions as what might fit in the 88 instead
Old 02-26-2006, 11:37 PM
jwsimons's Avatar
that could end up being a little tricky, only because the wiring had to be changed to work with the 95 motor. what i mean is, do you know if you have an obd1 ecu? other than that, as to your ?, any d series, or zc, or even b series will pretty much bolt in, vtec or non.
Old 02-27-2006, 11:22 AM
from what i am gitting from the swap is that they left the original trotle botty intake from the 1.5 that was in it. So i can only presume that the wiring harness and the ecu is original for the 88 also. So i think that i would have to change the ecu and wiring harness to work with a newer multi port injection intake. That looks like a lot of work so is there any help for the d15b7? If not can i put an integra b18 motor in my 88 civic because i can get one and the ecu and wiring harness how rough would it be? Is it worth this swap.
Should d15b7 stay or go ?
Old 02-27-2006, 11:53 AM
if you wanna tear into the bottom end yous hould keep the D15. some a3 pistons and a y8 head will set you up with a nice 12.1:1 compression ratio.
Old 02-27-2006, 09:50 PM
beefing up the d15b7 is what i would like to do. because i just met a guy today that i used to go to highschool with and he has two 90, 91 civic hatchbacks with my moter in them he said that i can have free parts off them. So basically that means a spare moter to rebuild. Now one of his d15b7 moters had a 1.6 vetec head on it. Is that a disent match up?
Keep the info comming thanks people!!
Old 03-01-2006, 02:21 AM
jwsimons's Avatar
if the head is servicable.....yes!! i would grab it. and his ecu, wiring harness, sensors, intake....(hell if it was me id take the car..lmao)
Old 03-01-2006, 09:43 PM
take everything that jwsimmonds said. take that head for sure. is it a z6 or y8?
Old 10-07-2015, 06:49 PM
frazier2003's Avatar
ive got a 1995 Honda civic does anyone have ideas to get more horse power out of it
Quick Reply: 95 1.5 sohc 16v i need info
