02-20-2006, 12:32 AM
B18A1 Non Vtec to Vtec
I bought a 1990 Acura Integra GS with a B18A1 with a Non Vtec head. And I was wondering Which Head from the B series I can swap it out with to make it Vtec. Plus I plain to swap the engine in to a 89 CRX, how much trouble would that be, and what do I need to do the swap.
Thank You!
02-20-2006, 05:47 AM
RE: B18A1 Non Vtec to Vtec
b18c_ c1, c5 are the gsr and type r, then b18c3
__________________
getting there is half the fun, do it yourself
02-20-2006, 10:51 AM
DONT FOR GET THE ALMIGHTY B17A1.... 90-93 gsr 1.7 liter 170 hp..... those heads flow VERY well, but they are VERY hard to come by
02-20-2006, 12:36 PM
The B17 head is no different than the obd1 and obd2 B16 head
02-20-2006, 01:55 PM
Yeah, and you forgot to mention the B16.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
02-20-2006, 01:58 PM
yes it is.. the ports are different and so are the cams....
02-20-2006, 03:44 PM
but why would you want a b16 head on a b18 block? i understand they are both basically the same block, is there anything to be gained by using a 16 head? i did not think there would be, so i kept it to the 18's....
__________________
02-20-2006, 03:59 PM
If you get a B16 head, it will lower the compression. This would be good if you plan to run a forced induction set up.
__________________
HCF Chat Rocks!!!!
02-20-2006, 07:26 PM
u asked if there was much troble.. well a little ,non vtek to a v-yek takes new wiring on the ecu part and a new oil line to the head aswell..,,,
__________________
Nothin kike a 15 hour drive to let u know how your suspension is doing.
96 HB
Ya that silly wing is off now
Does it look like there are many TRACKS in my Area?
02-21-2006, 03:04 PM
Quote:
ORIGINAL: AgentofDarkness
not from a B17 head. but yeah from most B heads it will
use a SiR head. lower compression and best flowing.
Tags
92, b16, b16a, b18a1, civic, diy, ef, gsr, head, honda, kind, project, swap, turbo, vtec  |
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
