How can i get my civic faster?
Old 04-20-2005, 08:17 PM
fastfox23's Avatar
Default How can i get my civic faster?
My 2000 honda civic EX has a v-tec engine, headers, cool air intake, and a megan racing exhaust on it. Is there any way I can make my car faster without doing a engine swap.
Old 04-20-2005, 08:27 PM
Default RE: How can i get my civic faster?
unfortunately, with the d-series, boost is really the only way to go from here. a b-series has more potential than a d-series, but if you stay with it, id say boost it. how many miles do you have on your car right now? i would say keep it reliable, and keep boost to between 5-6psi. this will give you a noticeable difference in hp, but wont be ungodly fast by any means. most turbo'd d-series run high 14's to low 15's, depending on boost level, internal upgrades, driver skill, many things.
Old 04-20-2005, 09:25 PM
fast93civic's Avatar
Wait a minute, "
." Hell no, not neccessaraly. It really depends all on if you want to go all motor or turbo. You can make your civic pretty damn fast with out a turbo. But it all depends on what you want, turbos are good, but not the only option. Some of the things that you can get now are a aftermarket intake manifold, larger throttle body, bigger cam/s, bigger injectors, performance ECU and other. I mean yea if you want to get a turbo and drop about $2000 go for it, but for less you can do other things to make your car fast. I guess it also depends on how fast you want to go also.
Old 04-20-2005, 10:29 PM
finalimpact's Avatar
pistons and a cam would give u a decent set up. all depends on how fast your wanting to go and what kinda budget your working with.
Old 04-21-2005, 08:33 AM
Build the engine up like put pistons, cams, valves, polish the ports. etc. By doing all of this then throw a turbo on it then you will have one bad *** SOHC civic.
Old 04-21-2005, 02:00 PM
yea, hope you're made of money from.
Old 04-21-2005, 02:53 PM
ORIGINAL: fast93civic
This, coming from the guy who cut his front springs. Make a car fast yourself before you tell others how to go about it.
Old 04-21-2005, 03:59 PM
[sm=nxsmile.gif]
Old 04-21-2005, 04:01 PM
[sm=badidea.gif]
Old 04-21-2005, 07:20 PM
Nail I3unny's Avatar
ORIGINAL: hondabboy
[sm=nxsmile.gif]
nitrous + stock D16 = ouch
Quick Reply: How can i get my civic faster?
