d16z6 head
Old 05-13-2005, 10:35 PM
AnakinKenobe's Avatar
Default d16z6 head
Ok i finally figured out that when my motor was shipped it messed the head up and it was only a matter of time before my head blew... well it blew oil from the dizzy and i decided i needed a new head so i picked one up for $60 and luckly i have access to clean up the head and do a head gasket set, well do i need new head bolts and where do i get those and where is the best place to pick up a head gasket set???? should i go ahead and put better valves and valve springs in it ????
Old 05-13-2005, 11:23 PM
sacicons's Avatar
Default RE: d16z6 head
theres no better time than now. and look at ebay for a gasket set. oh, and remember that you cant retorque head bolts, but you CAN retorque headSTUDS, like ARPs, so thats not a bad investment, let alone that they are stronger than stockers.
Old 05-13-2005, 11:36 PM
LEVIII's Avatar
whered you get it for 60 bucks?
Old 05-13-2005, 11:49 PM
guy i know that has a garage out where i live, im getting the bottom end of the car for $40, i just won an auction for an engine stand for a $1 lol so i have a SOHC i can build... i can get a good hook up on honda parts, he even threw in the vtec solenoid ..
Old 05-14-2005, 12:01 AM
LEVIII's Avatar
Wow, good deal. DOnt the vtec solinoids go for 60 bucks sometimes?
Old 05-15-2005, 02:33 AM
Kappa22's Avatar
Yes you can. 43 lbs isn't enough to permanently twist them.
Old 05-15-2005, 09:15 AM
ok heres a question, my motor in my car is the d15b and the head i have is a d16z6, now i was reading on different forums that the d15b's head has amore aggressive cam, can i use the d15b cam in my d16z6 head???
Old 05-16-2005, 12:27 AM
sacicons's Avatar
you can retorque them? oh well, doesnt change my opinion. i would still go with the ARPs. pretty cheap compared to having them stretch or something down the road.
but i dont think you can use the d15b cam, i think its 3-stage Vtec, right? i doubt it would work well, if at all.
Old 05-16-2005, 09:34 AM
ok i wasnt sure, so ill just use my d16z6 cam..
Old 05-18-2005, 07:16 PM
you can use the cam from d15b into d16z6.i have just had d16z6 engine reconditioned we have used the cam from d15b.
Quick Reply: d16z6 head
