d16z6 head
RE: d16z6 head
hey has anyone ran a z6 head with a stock d15 intake mani...the dp mani....i put the head on a month opr so ago but didnt change the intake mani cuz i was just trying to get it runing quick...well i just had a chance to work on it again and i cant get it running...there is spark and enough compression to shoot a tissue ball out of each spark plug hole(dont have a tester)...do u think i cant get it runing due to the dx mani or?...any suggestions?
RE: d16z6 head
ORIGINAL: ..there is spark and enough compression to shoot a tissue ball out of each spark plug hole(dont have a tester)...
RE: d16z6 head
check your ignition timing off your dizzy, it will sit and crank all day but if ur 180 degrees of it wont start, just pull ur distributor and turn that thing that turns lol 180 degrees, but make sure before you do anything that 1. your plugs are gapped correctly. 2. all little wires and connectors are plugged in and finally your pulley and cam gear timing is perfect oh yea and ur firing order is correct....
