valve cover/spark plug seal removal help
#21
For whatever reason, the previous person used some white gasket sealant near the ends.
#22
Valve Cover Gasket Timing Chain
Need to replace the valve cover gasket.
Got 300,000 on the engine and the timing chain is due in the next 25,000.
If I decide to do the timing belt (in about a year) myself then will I need to replace the valve cover gasket again?
Thanks,
John
Thanks,
John
#23
i think honda recommends changing the valve cover gasket every time you remove the valve cover, but i don't think it's really necessary to change it that often. it should be fine to reuse
cvguy
02-24-2012 12:47 PM
ltkenbo
10-09-2011 11:55 AM
addiction2bass
10-09-2009 03:25 PM
danomatic93
03-21-2007 06:19 PM
