Blaster SS coil, and MSD cap and rotor
Old 04-28-2011, 12:08 PM
kk5150's Avatar
Default Blaster SS coil, and MSD cap and rotor
A while back i had 100 bucks to throw away so i thought i'd pick up this little setup.
Honda Civic MSD Blaster SS Ignition Coil
and you have to get
Honda Civic MSD Modified Distributor Cap & Rotor Kit
Ok. Installation on this is fairly easy if you have some sense of wiring. it is just cutting two wires and adding longer wire to them and attaching it to the coil. MSD's instructions are easy to follow if you can follow instructions well without pictures. Installation took ~45 min. i really took my time cause i didnt wanna mess anything up.
Ok now for the fun part. after double checking and making sure everything was hooked up right. i fired up the car. it started easier and quicker. which to me is a plus. less cranking on the starter, and less draw on the battery. after letting it sit, and making sure it didnt throw any CEL's for whatever reason i took it for a spin. right off the bat i noticed throttle response was a lot better. it seemed quicker and more responsive. In my SOHC vtec was a little more noticeable. idk why but it seemed like you could feel it a lot better.
This MSD ignition setup isnt gonna give you huge HP gains. It did however make a quite noticeable difference on the throttle response. Worth it? eh i'd say so. the plus side is. honda style coils around here go for about 80 bucks for a good one with warranty. but the MSD only being 47 does save some money if it goes bad, and coils go bad. Oh and you who live in states where smog is an issue, this IS CARB legal. so no swapping when you have to smog.
civicrippa98
06-02-2008 04:42 AM
civicrippa98
01-15-2008 07:59 AM
nightrider46
05-30-2007 08:41 PM
bigwill1384
09-24-2006 12:11 AM
nightrider46
07-18-2005 04:20 PM
Quick Reply: Blaster SS coil, and MSD cap and rotor
