bought a turbo! little help please?
So I Have bought an ebay turbo kit for my 93 honda civic dx hatch, yes I know ebay kits arent always the way to go, however im not going full out. I have an oil cooler setup I will hook up as well, how would I go about running this? Also, should I get bigger/better fuel injectors if so what should I get?
Doesnt seem like you have done much research. Yes, you will need bigger injectors unless you plan on staying under 150whp. Even then, the stockers might be too small. Bigger fuel pump is recommended as well.
You posted this in the wrong section as well. Moved to the turbos etc section
shadowcrow420
12-30-2009 11:53 PM
Deathsim89
06-18-2007 02:26 PM
