CEL/MPG question
welcome back ronj ,missed ya
I'll say again. P0135 would not be caused by a cracked header. This code indicates a problem with heater element circuit of the primary O2 sensor. Check whether dash fuse 15 is blown. If so, check the fuse 15 TSB in my signature. If fuse 15 is fine, measure the resistance of the heater element. It should be 10-40 Ohms.
Weeks ago, I bought a new O2 sensor and installed, then cleared the code. Started the car and the CEL reappeared 15 seconds later. Same code. Dusted the sensor off and returned it. (O2 sensor was factory replacement and expensive.)
Fuse 15 is good. Tested with a meter to be sure.
It also would be a good idea to test resistance of the O2 sensor heater element.
