00 si in need of new clutch which brand would you guys recommend
Old 07-18-2011, 06:47 AM
ale19859's Avatar
Default 00 si in need of new clutch which brand would you guys recommend
I have a 2000 Honda civic si and i need a new clutch which brand would you recommend me also the flywheel which would be best i was thinking on a ACT clutch stage 1 idk let me know what you guys think thanks im new to the Honda game so yea i need some help I appreciated
Old 07-18-2011, 08:08 AM
Any mods? Any reason to have an upgraded clutch?
Old 07-18-2011, 09:47 AM
Stock Honda clutch or Exedy clutch equivalent to stock.
Old 07-18-2011, 02:42 PM
If you're daily driving in traffic, you do not want a racing clutch.
Old 07-18-2011, 03:29 PM
Meh, certain brands have a heavier pressure plate than others. I had no problem DDing my JRSC D16 with a stage 2 competition clutch in traffic. I have heard ACT clutches are harder on the legs though.
However, I only had the stage 2 since my stock clutch would start to slip after a little bit.
OP, remember, an OEM replacement clutch is meant to last. A racing clutch is purely meant to hold the power you are putting down. I can see a performance clutch dying out much faster than an OEM clutch on a stock car.
Old 07-20-2011, 09:30 AM
ale19859's Avatar
Smile
thanks a lot for all your help i think im gonna go for an exedy clutch stage 1 it wouldnt hurt my civic right? and should i resurface the flywheel or get a new one? the only mod to the engine my car has is a short ram injen intake
Old 07-20-2011, 01:28 PM
Intake and exhaust stuff really doesnt add much power. A stock clutch can handle that with no problem. I am saying once you start boosting and exceeding like 30% more hp than what came with the motor, you should look towards upgrading.
Either get a replacement, or the stock on re-surfaced. Doesn't really matter.
There is no such thing as too much clutch. You can get a stage 5 if you really wanted. Yes, it would be pointless, but it wouldn't hurt anything except your leg after a while of DDing it. ;P
Old 07-20-2011, 02:58 PM
boiler1's Avatar
I changed my 00 si clutch at 80,000 mi and just sanded down the flywheel and wiped with brake cleaner. Unless you see major grooves I dont think you need to change the flywheel if you're just using a stock like replacement.
I would think that the heavier clutches would kill an old worn out clutch/slave cylinder.
juhaaan
06-14-2011 10:55 PM
rocky12345
09-06-2010 04:33 PM
graymonkey44
EK Swaps
06-18-2010 01:15 PM
inthezoneac
04-12-2008 03:05 PM
zz5
12-19-2006 10:51 PM
Quick Reply: 00 si in need of new clutch which brand would you guys recommend
