05 civic gear ratio specs
Old 01-10-2008, 04:03 PM
jeff_o's Avatar
Default 05 civic gear ratio specs
Hi guys, I crawled my way thru cyberspace to look for gear ratios of 05LX vs 05EX but i couldn't find anything. can someone point me to the right location. I got conflicting information when I search thru Honda dealer's used inventory specs.
Old 01-10-2008, 07:56 PM
Default RE: 05 civic gear ratio specs
I dont know either but I looked on wikipedia...
LX engine D17A1
EX engine D17A2
using google with search terms with the engine names you could probably find your info of gear ratios...this is just some general info:
D17A1
[ul][*]Found in:
[ul][*]2001-2005 Honda Civic DX/LX/VP
[ul][*]Displacement: 1668 cm³[*]Bore and Stroke: 75 mm X 94.4 mm[*]Compression: 9.5:1[*]Power: 115hp (86kW) @ 5600 rpm & 110 ft·lbf @ 4500 rpm[*]Valvetrain: SOHC[*]Fuel Control: OBD-2 MPFI [/ul][/ul][/ul]
D17A2
[ul][*]VTEC-E[*]Found in:
[ul][*]2001-2005 Honda Civic EX[*]2001-2005 Honda Civic Si (Canada only)
[ul][*]Displacement: 1668 cm³[*]Bore and Stroke: 74.98 mm X 94.4 mm[*]Compression: 9.9:1[*]Power: 127hp (95kW) @ 5800 rpm & 114 ft·lbf @ 4800 rpm[*]Valvetrain: SOHC VTEC-E[*]Fuel Control: OBD-2 MPFI [/ul][/ul][/ul]
Old 01-10-2008, 07:58 PM
Yeah, I found it on Google for ya with the engine name...
EX 5M Gear[/b] Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
Final Drive Axle Ratio 4.412
EX AUTO Gear[/b] Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio (:1) 4.067
HX 5M Gear[/b] Ratio
First 3.461
Second 1.750
Third 1.096
Fourth 0.857
Fifth 0.710
Reverse 3.231
Final Drive Axle Ratio 3.208
DX/LX 5M Gear[/b] Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
Final Drive Axle Ratio 4.111
DX/LX AUTO Gear[/b] Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio 4.067
http://honda-tech.com/zerothread?cmd...amp;id=2169563
Old 01-10-2008, 10:55 PM
Superb info bro.. thanks
Old 01-11-2008, 04:21 AM
jeff_o's Avatar
great info. thanks guys. now this leads to my next question. the LX and EX engine has the same displacement. the only diff is the compression and the other one is VTEC. but how is the EX engine able to produce more power than that of the LX?both are SOHC.
looking at the chart below from the 05 brochure, i find it surprising that the EX manual has lower mileage (37) at highways compared to the EX auto (38). is this something to do with the gear ratios? and surprisingly, the EX auto at city (31) has higher mpg than the LX auto (29). the EX is supposed to be more poweful and consumes more gas than the LX. but again maybe because of VTEC.
EPA Mileage Estimates
5spd man 32/38(DX/VP/LX) 32/37(EX)
4spd auto 29/38(DX/VP/LX) 31/38(EX)
mountain_man
04-16-2012 09:33 PM
caveman1990
11-16-2011 05:15 AM
civicex1995
10-05-2011 08:11 AM
civicex1995
10-04-2011 06:51 AM
sickcivic07
02-16-2006 04:51 PM
Quick Reply: 05 civic gear ratio specs
