2002 timing chain/water pump
I just read Honda started putting a timing chain in their engines starting in 2002. (correct me if I'm wrong). These timing chains are recomened to be changed much later then a timing belt. What about the water pump? When should that be changed? Do you still do it when you change the timing chain?
Timing chain is on the 02-05 Si, because it's a K-series engine. I am pretty sure that all other 01-05 models had the timing belt, as they were D-series engines. 105,000 miles is the recommended service interval for the belt.
