2003 Civic LX Break Suggestions?
Hi, I am looking to do normal maintenance for my car which has 60k miles on it.
What break pads do you recommend for the front disk breaks?
What rear drum pads do you recommend for the rear drum breaks?
RE: 2003 Civic LX Break Suggestions?
Here are the Honda OEM part # for a 2003 Civic LX
45022-S5D-H00PAD SET, FRONT $43.28 (includes both sides and pad shims)
I would get WearEver rotors from Advance Auto 2yr warranty(the OE replacement blanks) (if needed) cost about $25 ea.
43153-S5A-A01SHOE, RR. BRAKE $11.74ea -4 req'd (2 on each side) so $46.96, (I do not know why they only sell them separately)
New drum brake hardware is alwaysrecommended when installing new shoes
43367-SH5-003SPRING, Right side. ADJUSTER $2.69
43377-SH5-003SPRING, Left side. ADJUSTER $2.69
43172-S04-003SPRING B$1.15ea - 2 req'd (one on each side) so $2.30
43171-S04-003SPRING A $1.12ea - 2 req'd (one on each side) so $2.24
I would get WearEver Drums from Advance Auto 2yr warranty(OE replacement, nothing fancy)(if needed) cost about $25ea.
*****Are you sure you even need rear brakes?*****
The front/rear braking split for a disc/drum brake system is 80%front and 20% rear,
so you usually wear out the frontsTWICE before rears are needed.
Most likely your rears will just need a "clean & adjust" (i.e. -sprayed with brake cleaner, and then adjusted up to contact the drums)
http://www.slhondaparts.com/browse.asp
Raybestos is a great brand, but in my experiencewith aftermarket front pads (including Raybestos) for Hondas, theyare always "too thick" by about 1/8", and you cannot get the caliper over the new pads, so that's why I recommend going OEM.
Thanks for the information.
im going to save this. itll be useful for reference
ORIGINAL: TheJGB3
KFRG
02-07-2010 03:28 PM
Jim03ex
09-15-2008 12:01 PM
browndude
08-28-2006 07:30 AM
manleyhanley76
04-28-2006 12:03 PM
mrblackhp
15
07-20-2005 12:59 AM
