2004 LX engine information
Tried search and google to no avail. I have a 2004 Civic LX sedan with a 5 speed.
Wondering some stock specs on my engine and transmission, if you guys know them or where I can find them.
I've got quite a few miles left on warranty but once it's up I would like to do a swap to my car and hopefully turbo that setup. I run mobil 1 in the engine religiously changing at or before 5000 miles and it runs sweet as a nut and doesn't burn any oil at just under 70000.
The plan is to buy a used engine that's not blown and rebuild it forged, etc and swap it and a better tranny in and install a turbo kit.
Any info let me know, thanks!
RE: 2004 LX engine information
ORIGINAL: monkeydude3
2004 Civic LX 5 Speed Manual
Engineering[/align]
Engine Type: In-Line 4-Cylinder
Engine Block/Cylinder Head: Aluminum-Alloy
Displacement (cc): 1668
Horsepower @ rpm (SAE net): 115 @ 6100
Torque (lb.-ft. @ rpm): 110 @ 4500
Bore and Stroke (mm): 75 x 94.4
Compression Ratio: 9.5:1
Valve Train: 16-Valve SOHC
Multi-Point Fuel Injection
Front-Wheel Drive
CARB Emissions Rating: ULEV
Direct Ignition System with Immobilizer
110,000 Mile Tune-Up Interval[/align]
Transmission[/align]
5-Speed Manual Transmission Gear Ratios
[/align]
1st: [/align]
3.462[/align]
[/align]
2nd: [/align]
1.870[/align]
[/align]
3rd: [/align]
1.241[/align]
[/align]
4th: [/align]
0.970[/align]
[/align]
5th: [/align]
0.711[/align]
[/align]
Reverse: [/align]
3.231[/align]
[/align]
Final Drive: [/align]
4.111[/align][/align][/align]
EPA Mileage Estimates/Fuel Capacity*[/align]
5-Speed Manual (City/Highway): 32/38
4-Speed Automatic (City/Highway): 29/38
Crankcase (qt.): 4.4
Coolant System (qt., MT/AT): 5.3/5.2
Fuel (gal.): 13.2
Required Fuel: Regular Unleaded[/align]
Exterior Measurements[/align]
Wheelbase (in.): 103.1
Length (in.): 175.4
Height (in.): 56.7
Width (in.): 67.5
Track (in., front/rear): 57.8/57.8
Curb Weight (lbs., MT/AT): 2560 / 2606
Weight Distribution (%, front/rear, MT): 60/40
Weight Distribution (%, front/rear, AT): 61/39[/align]
Nice but in the summer i can pull over 40mpg out of it... hehe
Okay... well I guess I will do a search for information on that unless you have some info.
If I do modify this car when the time comes, I would like to maintain the driveability where is now. If I swap engines and such, will all the dash lights, gauges,etc still work the same?
What kind of life can I expect from my 1.7? I have run mobil 1 since I bought it, andit has run like a top since I've had it.
Also, is there a thread on here for maintenance intervals for fluids, belts, tuneup, etc? I know what the manual and honda say, but are these pretty accurate or should I do anything sooner?
Thanks a lot!
Thanks a lot!
skiier3_9
07-26-2005 11:25 AM
