5w20 oil to 5w30
Old 08-24-2007, 02:08 AM
PNK SLP's Avatar
Default RE: 5w20 oil to 5w30
on my 300zx's i was used 10w30 then i changed over to 15w30..i had no problems, next time u use change ur oil just use all 5w30...dont mix it. I seriously dont think it will be a problem....oh dont listen to a honda sells person, all they want is ur money an time.had the same problem with nissan...
try it out for 2500miles or so, if no problems ...then ur good to go.
Old 08-24-2007, 12:09 PM
tknaub's Avatar
what kind of problem could i possibly face by changing to 5w 30?
Old 08-24-2007, 01:45 PM
HONDA_GUY's Avatar
Walmart should have it...... pretty much the only place around here that has it.
Old 08-24-2007, 02:24 PM
well the real question is WILL IT HURT THE MOTOR????????
Old 08-24-2007, 05:34 PM
tknaub's Avatar
ORIGINAL: addiction2bass
Thank you! My warrarnty is gone, so im not worried about that, but i want to keep myD17 until i can buy a K20.Therefore would buying 5w-30 bea bad idea?
Old 08-26-2007, 12:14 AM
http://www.synlube.com/sae5w-20.htm
Read that link. I've read the same thing somewhere else too. Honda only says to use 5w-20 because it saves them money by making their cars have better gas milage. It'll give you a little bit better milage but 5w-30 is a lot better for the engine and will increase your engine life.
Old 08-26-2007, 04:16 AM
AOL.COM's Avatar
5w 30 will NOT hurt your car , like weirddan said its only to get better gas milage , lots of new cars these days are using thinner oils
a few year ago most cars use 10-30 , but now most use 5-30
Old 08-26-2007, 09:08 AM
There is evidence that the piston rings will see more lubrication with 5-20 instead of 5-30. The thinner oil will lubricate the top end better. [/align][/align]All you wanted to know about this topic an much more go to http://theoildrop.server101.com/forums better know as bobistheoilguy.com [/align][/align]Tons of great info there. Highly recommended![/align]
kevin_405
07-31-2009 08:18 AM
oilltd
06-10-2008 04:06 PM
DickG.
05-23-2008 02:44 PM
DickG.
05-20-2008 03:29 PM
Quick Reply: 5w20 oil to 5w30
