94 civic
Old 09-26-2009, 03:16 PM
candyman420's Avatar
Default 94 civic
so i got a 94 civic that the drivers window just stopped working... got the window to go back up by putting a battery directly to the wire on the power window motor... now does this mean that the window motor is still good and the switch is bad ?? the switch still works for the pass side window... but not the driver side
Old 09-26-2009, 03:20 PM
first check your fuse under dash, if its all good then get a test light and test your switch.
Old 09-26-2009, 03:24 PM
its the drivers side master switch.. if the fuse was bad would the whole switch not work... not just drive window? i willcheck anyways i guess..i dont have fuse box cover witch fuse is for the switch?
Old 09-26-2009, 03:33 PM
