95 Civic fuel needle problem
Old 10-18-2009, 11:03 PM
1995CivicEXBMF's Avatar
Default 95 Civic fuel needle problem
Ok back with another problem with my Instrument Cluster Fuel needle. I fixed all the wiring (I think) and purchased a new Instrument Cluster to replace the old one i broke. The problem is that the needle was stuck on FULL when it should have been HALF.
I drove the car for a few miles then turned off the engine and left it off for awhile. When I started it up again I saw the Fuel Needled go down to where it should be and drove off, after about 5 miles and went back and stuck on FULL. This happen 3 times today.
At first I thought it could be that my FLOAT was sticking in my gas tank but never did that in my old Instrument Cluster. Does anyone know what could cause my Fuel Needle to act this way?
Old 10-18-2009, 11:05 PM
it may be the gauge is your fuel gauge good on the old cluster? if so put it into the new cluster and see
Old 10-18-2009, 11:12 PM
I cant do that I broke the needle on the old cluster
Old 10-19-2009, 06:26 AM
I'd agree it's probably the gauge itself, since your old one worked OK.
If the wire back to the tank shorts to ground, the gauge will go all the way to full. You could rule out the tank by unplugging the sender at the tank. That should cause the gauge to read empty all the time.
Old 10-19-2009, 11:10 PM
yeah since i dont know how many miles i can get to a full tank just yet i need that needle
Old 10-19-2009, 11:14 PM
however now the needle is acting as it should but i have less then half a tank which i believe is where it should be
vXc760
09-17-2012 07:05 PM
97Ej8
03-26-2012 06:29 AM
project94
03-21-2012 04:38 AM
carlosncali
07-06-2011 06:34 AM
addiction2bass
10-04-2008 04:29 PM
Quick Reply: 95 Civic fuel needle problem
