95 Civic Power steering HELP
Drain Plug
I know it's a little late but I would make sure the power steering drain plug is securely tightened. It is located on the drivers-side steering rack boot (mine was facing up towards the engine.
One of my old mechanics left this slightly loosened. I figured it out as soon as I looked at it but to the untrained eye, it could appear to be a leak. Just check and make sure that it is tightened all of the way (to anyone else out there that has the same problem.
ECK! I had to have my Rack & Pinion replaced last Winter..it cost like $900 at Precision Auto Care & took a day & 1/2 to do(or maybe they were busy that day). I don't know what to suggestion for you man...But I have heard you put the rack together OUTSIDE the car then install it instead of just inside the car piece by piece.
Edit: Ok I was on the 1st page & didn't even look at the date....well that sucks..
took the two pipes out (1 was a small metal pipe with 14ml bolt and the other 1 was the pressure hose metel hose that goes into a rubber hose and connects to the pump and managed to trace the leak to the there
norbster86
02-11-2010 04:52 AM
prodigyskate5
01-21-2009 01:13 PM
trustdestruction
15
01-17-2009 05:13 PM
addiction2bass
02-13-2008 07:59 PM
