95 Del Sol SI poll
Old 08-14-2008, 12:03 AM
Flippinjig's Avatar
Default 95 Del Sol SI poll
Hi all,
New to forum and am curious.
Do you own a 95 Del Sol SI and what have you done to it?
Old 08-14-2008, 12:45 AM
I own a 93 Del Sol Si
here's my mod list:
Engine/Performance:
AEM Short Ram Intake
AEM Dryflow Air Filter
Megan Racing 4-2-1 Header
Magnaflow Direct-fit High-Flow Catalytic Converter
Apex-I World Sport 2 Cat-back Exhaust
Polyurethane Exhaust Hangers
Short Shifter
Energy Suspension Polyurethane Shifter Bushings
Suspension/Wheels/Tires:
Azul Cross6 17”x7” Hyperblack Rims
Nexen N5000 205/40/17 Tires
KYB AGX Shocks and Struts
KYB Strut Mounts
KYB Strut Boots
H&R Sport Springs (Drop: 1.8” Front, 1.6” Rear)
Front and Rear Upper Strut Bars
Audio/Visual:
Sony xPlod Head Unit
Sony xPlod 4-way Speakers (5 ¼” Front, 6 ½” Rear)
Pyramid 2” Soft Dome Tweeters with Visonik 12dB Crossovers
Profile Baja 700W 4-channel Amplifier
MA Audio Sealed Box with (2) 10” Subwoofers
Appearance:
Polyurethane Mugen Replica Front Lip
Blue Painted Valve Cover with Aluminum sanded lettering
Blue Painted Distributor Cap
Blue Oil Dipstick Handle
Black Leather with Blue Stitching Shift Boot
Black Leather with Blue Stitching E-brake Boot
Brake Master Cylinder and Clutch Master Cylinder Blue Covers
Billet Aluminum Blue Battery Tie-Down
Spoon Billet Aluminum Oil Cap
Spoon Billet Aluminum 1.3 Radiator Cap
Blue Valve Cover Breather Filter
Aluminum Racing Pedals
JDM Antenna Block-off Plate
OEM Si Emblem (‘01+ Si emblem)
“SOHC VTEC” Decals – OEM Style
Smoked Front Bumper Reflectors
Black OEM Style Headlights
Black OEM Style Foglights
Smoked Bumper Side Markers
Sylvania Silverstar H4 Headlight Bulbs
Polarg Super White License Plate Light Bulbs -168
Tinted Taillights
SuperBrightLEDs.com Luxeon LED Taillight Bulbs – RED - 1157
SuperBrightLEDs.com LED Taillight Reflector Bulbs – RED -168
SuperBrightLEDs.com LED Rear Turn Signal Bulbs - Amber - 1156
Oznium Blue 5mm Gauge Cluster LEDs
Oznium Blue 5mm A/C Control LEDS
Oznium Blue 5mm LED Ashtray Light
Oznium 24 Bulb Super-White LED Dome Light
Oznium 2.4” White Flexstrip LEDs Under Dash (Turn on with Dome Light)
VTEC Floor Light:
Oznium 4.7” Blue Flexstrip LEDs Under Each Side of Dash
Oznium 2.4” Blue Flexstrip LEDs Under Each Seat
Trunk Light:
Oznium 2.4” Blue Flexstrip LEDs Behind Subwoofer Box
Oznium 1.2” Blue Flexstrip LEDs (One Shining on each subwoofer)
Fluids:
Royal Purple Synthetic 10W-30 Oil/ K&N Oil Filter
Mobil1 10W-30 Oil (transmission)
Prestone Synthetic Dot4 Brake Fluid (also clutch)
Prestone 50/50 Pre-mixed anti-freeze
Prestone Power Steering Fluid
Old 08-14-2008, 07:28 PM
Flippinjig's Avatar
Wow that's impressive. I've got a chance to get a 95 but the motor is blown. It's a long ways from being as nice as yours. Do you have a suggestion on where I could find an engine?
Old 08-14-2008, 08:58 PM
thanks. the only thing i don't like about my car is the paint is whack. you can't tell from the pics, but it's pretty messed up paint. it had some chipping, so i sanded the chipping areas down smooth and used some touch up paint, and some clear coat, but i couldn't get it to shine. so i have these spots on my car where the paint is really dull. pisses me off every time i see it.
about the motor, you can find engines on ebay and craigslist.
what's your budget for putting an engine in it? are you looking to put a close to stock engine in it or do you want to swap in a b-series or something?
what exactly is wrong with the engine? is it repairable or does it have a hole in the block or something?
Old 08-14-2008, 09:10 PM
Flippinjig's Avatar
Bummer about the paint.
95 has a hole in the block. Previous owner did an oil change and didn't get the old gasket off. Lost oil on the interstate. I'm not sure what motor is in it. He said something about D16Z????? Said it still turns over too. Anyway what is the difference from stock and B series, price and performance?
Old 08-14-2008, 09:17 PM
stock (d16z6, SOHC VTEC) is 125hp. b16 is DOHC VTEC with 158hp.
however, you can find a d16z6 or a jdm d15b (jdm d16z6 equivalent, actually has 130hp) on ebay for like 600 bucks. b16's run like 2000 for the swap.
it'd be a lot easier to just replace the motor with stock or a JDM d15b. if you got a b16 you'd need a b-series transmission and a bunch more stuff.
if you get a JDM d15b, get the JDM tranny too (usually is included with the motor on ebay), it has a LSD in it and is pretty nice
the good thing about the JDM motors is they have low mileage
Old 08-14-2008, 09:37 PM
Flippinjig's Avatar
600 bucks sounds good to me. JDM??? Is that a company that deals in used motors? LSD??? Now I'm really showing my ignorance!
Old 08-14-2008, 09:48 PM
lol. it's alright man. i'll be happy to answer any questions regarding these terms.
JDM= Japan Domestic Market
JDM engines are engines that have been imported from Japan. They usually have low miles on them. I guess Japanese people buy new cars often or something.
LSD= Limited Slip Differential
An LSD is a part in the transmission (most transmissions don't have one, they have an open differential) that helps distribute engine power more equally to the wheels. This helps with traction off the line
It will also around a corner distribute more power to the wheel with the most traction. The same thing will happen if one wheel enters sand or some other obstruction, to give more power to the wheel with the most traction. This helps with traction/stability around corners, through sand or standing water, etc.
definitely worth having
Old 08-14-2008, 09:49 PM
for more info on LSDs, check the stickys in the transmission section
Old 08-14-2008, 10:12 PM
Flippinjig's Avatar
Hey thanks for the patience. So if I get a JDM D15b with a tranny (is that a 5 speed?) it will bolt right up? Would you spend money on new half shafts are anything else? Do you have a suggestion for a good shop manual because I bet I'll need one.
Quick Reply: 95 Del Sol SI poll
