'96-'00 B16A swap
Old 05-19-2010, 01:16 PM
Johnny Appleseed's Avatar
6G Japan '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
  #22
Old 05-19-2010, 01:19 PM
...NEED4SPEED...'s Avatar
sorry i got a poopy phone and can't do hardly anything. i'm lucky enough to be able to post...
  #23
Old 05-19-2010, 01:51 PM
Originally Posted by Johnny Appleseed
S40-1795195
Check the stamp on the block (here's what to look for) and let us know what it says.
Johnny, check the stamp again. If it is a B16, it'll say B16(and then either an "a", or "a3", or "a2" for the most part)
How often do Turbos blow?
Turbo's don't "blow", but the seals can go bad, causing you to burn/leak a lot of oil.
Originally Posted by N0safebetdx
if your running an insane amount of boost on a motor that can't handle it and that isnt tuned properly then yes youu will blow your motor up
I bolded, italicized (sp?), and underlined the key phrase.
Originally Posted by ...NEED4SPEED...
correct me anyone if i'm wrong but if i remember correctly on stock internals your motor can only take like 6-8psi... any more and bye bye to your motor.
I'm pretty sure no more then 10lbs...
PSI is irrelevant. A huge HX35 turbo on 5 lbs will make more power than a tiny t25 on 5 lbs, since it forcing more air into the combustion chamber. I believe Reaper stated something about the max. power a B16 can put out on stock internals.
OP, read through the stickies in the Forced Induction section. There's one there that will spell out everything you need and might want when turboing your car.
  #24
Old 05-20-2010, 04:44 AM
Yup, PSI is irrelevant. 10psi in a straw is a lot less air than 10psi in a 6" sewer pipe of the same length.
Actually, my estimates were low; I double-checked the Forced induction FAQ and apparently the B-series vtec engines can take about 350whp on the stock internals assuming the tune is good.
Also, turbos can leak, but they can also develop shaft play where the shaft connecting the turbine and compressor wheels becomes loose and the whole assembly has play in it. It makes quite a lot of noise when it happens
  #25
Old 05-20-2010, 04:49 AM
N0safebetdx's Avatar
shawty
Yes after I wrote that I did a lot of reading
  #26
Old 05-20-2010, 12:37 PM
wow i'm learnin a lot here... lol.
crx9191
06-07-2007 02:37 PM
cadman421
EK Swaps
05-11-2007 12:47 AM
Hot94vtec
01-19-2006 07:57 AM
LEVIII
10-18-2005 01:31 AM
Mossy
EK Swaps
04-19-2005 07:52 PM
Quick Reply: '96-'00 B16A swap
