'99 Civic dying with check engine light on
Old 05-11-2007, 08:49 PM
pjones's Avatar
Default '99 Civic dying with check engine light on
90,000 miles. Last year it started...car died at an intersection, but restarted OK. Progressed to dying and not restarting, towed home. No spark. Replaced coil and ignitor, ran fine for months. Started dying at intersections or low rpm situations. Dealer couldn't find anything wrong (wouldn't repeat for them). Replaced fuel filter, plugs, distributor cap, rotor. Died again, replaced main relay located to right of glove box. Ran ok for a couple weeks, then the Check Engine light came on while driving, no other symptoms. A day later it would start but would die when you tried to drive. Towed it home and it sits waiting on more troubleshooting.
Looking for advice.
Thanks, Paul
Old 05-11-2007, 09:13 PM
Default RE: '99 Civic dying with check engine light on
lol i dont mean to ruin your nice list of fixtures but have you checked your battery or your tranny? i have a 99 civic and mine did the same thing does your stereo light dim when you start it?
Old 05-12-2007, 06:21 AM
cyberx32's Avatar
The car isnt throwing out any codes?
Old 05-12-2007, 01:17 PM
pjones's Avatar
"Catalyst Efficiency Below Threshold (bank 1) P0420"
Old 05-12-2007, 01:32 PM
i got an idea. the amount u spend trying to fix it, u can rather buy a whole new block =O
Old 05-12-2007, 03:04 PM
pjones's Avatar
Today I did the exhaust backpressure test with a vacuum gauge, the cat didn't show signs of plugging. Maybe a faulty sensor?
Old 05-14-2007, 03:29 AM
Sounds like it could be a dead o2 sensor. But the dealer really should have been able to tell if that was the case.
Have you tried running a compression test?
Old 09-01-2007, 11:33 AM
pjones's Avatar
Turned out to be bad wiring in the distributor. Saw some arc flash tracks...powder gray stuff on the outside of the wiring harness at the distributor. Replaced it problem never returned.
Old 09-01-2007, 04:59 PM
cyberx32's Avatar
Im glad you found the problem. Sometimes you have to fix so many things before you actually get to the real problem.
Rool_908
01-03-2012 07:03 AM
mhlden
10-02-2011 07:14 AM
towelie
08-30-2010 05:08 PM
Stumasters
11-12-2007 07:12 AM
LT1T/AM6
07-15-2006 12:50 AM
Quick Reply: '99 Civic dying with check engine light on
