answer this for me please
hello can someone answer this question please, i just swapped a b16a awhile back but i am confused now cause it says b16a not b16a1 or b16a2, so what does that mean when it says b16a with no number after the a like it is a dohc v-tec and it moves but iam lost why it has no number after the a? also was wondering on the stock hp and torque?
B16A1
VTEC
Found in:
Early Integra, CRX, Civic'1.6i-VT'(EE8)(EE9)
Displacement: Template:Convert/aa 1.6 liter (1595)
Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
Compression: 10.2:1
Power: 150 hp (112 kW) @ 7600 rpm
Torque: 106 lb·ft (144 N·m) @ 7100 rpm
Redline: 8000 rpm
Transmission: Y2
aluminium casting
B16A2
VTEC
Found in:
1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
1992-1997 Honda Civic Del Sol EDM VTi (EG)
1996-1997 Honda Civic Del Sol USDM "VTEC"
1999-2000 Honda Civic USDM Si (EM1)
1999-2000 Honda Civic CAN SiR (EM1)
Displacement: 1,595 cc (97.3 cu in)
Compression: 10.2:1
Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
Transmission: Y21 or S4C
Redline...8000 rpm
Rev Limit...8450 rpm
VTEC Engagement...5,500 rpm
aluminium casting
The numbers I believe only Reference what car the B16 came out of. I'm not a professional just giving my opinion.
VTEC
Found in:
Compression: 10.2:1
Redline: 8000 rpm
Transmission: Y2
aluminium casting
B16A2
VTEC
Found in:
Compression: 10.2:1
Redline...8000 rpm
aluminium casting
To continue along with the trend...
JDM B16A (Second Generation)
* Found in:
* 1991-1994 JDM Honda Civic Sir/SiRII (EG6)
* 1991-1993 JDM Honda Civic Ferio SiR (EG9)
* 1992-1995 JDM Honda CRX Delsol SiR (EG2)
* 1995-1998 JDM Honda Civic Sir/SiRII (EK4)
* 1995-1998 JDM Honda Civic Ferio Si (EK4)
o
+ Displacement: 1,595 cc (97.3 cu in) 1.6 liter
+ Compression: 10.4:1
+ Bore: 81.0 mm (3.2 in)
+ Stroke: 77.4 mm (3.0 in)
+ Rod Length: 134 mm (5.3 in)
+ Rod/stroke ratio: 1.745
+ Power: MT: 170 PS (125 kW; 168 hp) @ 7,800 rpm & 16.0 kg·m (157 N·m; 116 ft·lbf) @ 7,300rpm (AT: 160 PS (118 kW; 158 hp) @ 7,300 rpm & 15.6 kg·m (153 N·m; 113 ft·lbf) @ 6,500rpm)
+ Redline: 8200 rpm (AT: 7700 rpm)
+ Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
+ ECU code: P28 (EG2), P30 (EG2/EG6)
+ ODB1/ODB2
Link
In short, you have the JDM B16 motor in the car.
* Found in:
o
+ ODB1/ODB2
Link
wsauercivic
07-06-2005 12:58 PM
hondaisforamericatoo
06-12-2005 05:29 PM
Forty04
03-29-2005 01:56 AM
dimpy831
03-09-2005 09:33 PM
