Antenna question
Old 10-21-2011, 11:18 AM
Meanie's Avatar
Default Antenna question
Anyone know if the top portion (metal part) of the antenna can be separated from the bottom portion (plastic tube and cable) without requiring the need to replace the whole assembly on a '93 Civic CX?
Thank you
Old 10-21-2011, 12:09 PM
It's one piece. The whole assembly should be less than $30 at a dealer. Follow the instructions carefully about threading the cable.
Old 01-23-2012, 04:03 PM
airmanjason's Avatar
I have a 97 Civic DX haveing trouble replaceing my Antenna.Is it hard to take out the OEM Antenna ? Thanks for your help
Old 01-23-2012, 04:05 PM
It is a PITA to replace from what I remember when replacing the one on my 93 Civic years ago.
Old 01-23-2012, 04:21 PM
Nah, they're simple to replace.
From the passenger side, reach behind the radio and unplug the antenna cable. Then on the left side, pull the cable back across under the dash so it is laying on the left side floor.
Remove the two screws at the base of the old antenna and pull it out some. DO NOT PULL THE CABLE ALL THE WAY OUT OF THE CAR. You need access to the bottom end.
Cut the cable off of the old antenna. Throw old antenna away. Tape the radio plug of the new antenna onto the top end of the old cable.
Use the old cable to pull the new cable down into the car. Install the new antenna on the roof.
Remove the tape. Throw away the old cable. Thread the new cable across to the radio and plug it in.
m@nny
03-05-2010 12:40 PM
soulshadow2233
12-20-2006 08:41 PM
Novahawk13
07-20-2005 12:20 PM
ratbastrd
04-18-2005 08:48 PM
RandomCharacter
03-26-2005 12:37 AM
Quick Reply: Antenna question
