Any advice on where to start on my 99 EX?? First Car
Old 09-07-2008, 08:54 PM
Originally Posted by 94hondacivicEX
there is no point of having just an intake or just exhaust the motor runs better with exhaust and intake they are the breathing components when you get just an intake it will actually suck because if all the air is being brought in than it has to have a good flowing exhaust to let it out
yes, for the full effect you need both.
intake, header, exhaust, and high-flow cat are all upgrades that compliment each other in power when combined.
Old 09-07-2008, 08:59 PM
My best advice for buying things is to browse websites and forums and youtube and figure out what you want, and then go to ebay and search for that. If you know what you want prior to visiting ebay, ebay can be a great tool for finding hella good deals on brand name parts.
Old 09-08-2008, 02:51 AM
GoreCivic328's Avatar
thanks for all your help guys!
so after i get the exaust tken care of, ill move on to a high flow cat. converter? and then to a cold air intake?
Old 09-08-2008, 03:40 AM
yea, either will be good for the next step
i recommend these. good brand, no welding required.
http://store.summitracing.com/partde...5&autoview=sku
Old 09-08-2008, 10:45 AM
ok thanks again man,
is there any way i can tell what engine i have? 99 Civic ex 2 door??
Old 09-08-2008, 11:00 AM
D16Y8
VTEC
Also available in New Zealand under the code D16Y6
  • Found in
    • 1999-2000 Honda Civic SE 1.6 Vtec (UK)
    • 1997-1998 Honda Civic EX Sedan
    • 1996-1998 Honda Civic EX Coupe
    • 1996-2000 Honda Civic EX (US)
    • 1996-2000 Honda Civic SI (Canada Only)
    • 1997-2000 Acura 1.6EL (Canada Only)
    • 1996-1997 Honda del Sol Si
      • Displacement : 1590 cm³
      • Bore and Stroke : 75 mm X 90 mm
      • Compression : 9.6:1
      • D16Y8 1.6 16V SOHC VTEC PGM-FI 1590
      • 127 hp@6600 rpm 108tq@5500 rpm
      • Head Code : P2J
      • Piston Code : P2P
      • Redline 6900 rpm
      • ECU Code : P2P
Old 09-08-2008, 12:39 PM
D16Y8
VTEC
  • Found in
      • Head Code : P2J
      • Piston Code : P2P
      • Redline 6900 rpm
      • ECU Code : P2P
so i am ridin vtec? is this a good engine? tryin to figure out where i stand xD
Old 09-08-2008, 12:57 PM
It's among the best of Honda SOHC motors; However, Honda DOHC engines are better than it.
Yea, you have VTEC. How VTEC Works: http://www.honda-marine.com/video/VTEC.wmv (your engine does not engage VTEC at 4500RPM, contrary to the example in the video)
After you watch the video the following will make more sense:
The difference between SOHC and DOHC VTEC though is that SOHC VTEC only can change the intake valves lift/duration by using the VTEC lobes because the spark plugs are in the way of the exhaust side. DOHC VTEC changes both the intake and exhaust valves lift/duration, because the spark plugs are in between the two cams and aren't in the way, with one cam controlling intake and the other controlling exhaust. That's pretty much the main difference.
Old 09-08-2008, 02:18 PM
thanks man, good to know i have something half decent to work with. =]
hopefully ill be able to beef this thing up performance wise, so it wont be dragging behind my friends' rides any longer, lol
Old 09-08-2008, 06:07 PM
yea, sadly though to get much real power out of a D-series you have to either do a huge build, or slap on a turbo or spray some nitrous, or any combination of those.
Y_dolan
09-10-2013 11:58 AM
psl95civic
12-17-2011 08:17 AM
cromulius
03-14-2011 04:08 AM
rhs31
08-03-2007 04:36 PM
alpeffers
08-03-2007 02:57 AM
Quick Reply: Any advice on where to start on my 99 EX?? First Car
