Any Suggestions of where my Trunk leaking from
Old 04-12-2009, 08:00 AM
boricuapr_1's Avatar
Default Any Suggestions of where my Trunk leaking from
Well i bought this 98 Civic EX before a deployment, got back and want to do a couple of things to it but i have a leak in the trunk and is driving me crazy :evil:, i already bought a brand new trunk rubber seal that cost me about $50, and i've been trying some silicon in the area that i thought might it been the problem, theres no rust in the area or any signs of punctures or wreckage and im running out of options to prevent the leakage, any comments are more than welcome and ill be trying almost anything that is suggested
Thanks in advance for all the inputs or ideas :idea:
im going to try to upload some pictures, never done it so hopefully comes ok
General area of the Problem
Side View
Bottom View
Silicon Area
Water Spot
Old 04-12-2009, 08:28 AM
if the trunk seal is not tight on the metal lip it can leak right around the seal if its loose.
hard to tell by those pictures tho.
one thing that is easily overlooked is the sunroofs drains. they rub right down the roof and side pillars and then exit thru the rear quarter area i believe... if the holes get clogged from dirt build up it can force leaking... or if the hose is just old and busted if could also leak inside the trunk.
simply use a long thick wire or a air hose to also push it in the sunroofs drain vents and blow the air thru the drain hole.
and if that all fails with finding the leak then remove the trunk carpet and get a friend and go to your local car wash drop some quarters and you climb into the truck with a flash light and have your friend spray the taillights, then spray around the trunk cracks and start low and work the way up and around and then spray around the back glass, and then around the sunroof.
and when you find the leak start banging on the trunk lid to tel your friend to stop for a second and tell you where its leaking
Old 04-12-2009, 01:12 PM
SPLAT's Avatar
On the Hatch's, they are notorious for leaking behind the taillight's, the gasket needs to be replaced.
Old 04-12-2009, 01:38 PM
315 Customs's Avatar
almost always tail light gasket leaking
dnspare
09-03-2009 10:41 PM
germancivic
02-04-2008 05:59 PM
s0ulj3r
01-14-2008 07:41 PM
addiction2bass
08-27-2006 04:56 PM
mill$civic
12-13-2005 05:36 PM
Quick Reply: Any Suggestions of where my Trunk leaking from
