Auto tranny performance
Old 06-04-2007, 12:34 PM
civkid's Avatar
Default Auto tranny performance
Car; 93 EX coupe(D16 vtec)
Question; Does having an auto tranny affect performance greatly, because the lower gears are pretty slow, and are there tings I can do to my transmission for better performance(without swapping to a maunal)-sry if this is a repost
Old 06-04-2007, 12:35 PM
civkid's Avatar
Default RE: Auto tranny performance
*manual*
Old 06-04-2007, 01:29 PM
Kommando's Avatar
It depends on the car and the tranny. Typically, stock autos will absorb more power and not transmit as much power to the wheels as a manual. They also tend to be heavier.
For better performance you could do a performance rebuild with better clutches. You could also try to find a compatible limited-slip diff. You may even try different torque converters and different tranny fluids.
Old 06-04-2007, 01:39 PM
WhiteCivic98's Avatar
Member
ahigh stall torque converter will help your launches. as far as moving, turbo, supercharger, or spray. you could build up your engine with a new set of cams, high compression pistons, edelbrok IM, and a good set of headers and exhuast and that'll help you movetoo. There isnt much you can do to a Honda automatic cuz most honda enthusiasts find it easier to swap to manual and as a result the automatic aftermarket is VERY small.
Old 06-04-2007, 01:46 PM
the 0-60 times are a lot slower, along with quarter miles. If you decide to drive it like a stick (going through the gears manually), you're just going to waste gas with a very small result (maybe .5s off the 0-60 time, if that). You can build up the auto transmission with better clutches and such (try http://www.jegs.com/), but you might as well just swap to a 5-speed. Honestly, from what I've seen and heard, it's not that hard for the backyard mechanic to do in a weekend (or a day, if said backyard mechanic has prior trans. swap experience). Also, just as a side note, forced induction murders auto trannies.
Old 06-04-2007, 08:24 PM
phan10m's Avatar
if i went manny, do i gotta switch out the engine or the just the transmission
Old 06-04-2007, 08:27 PM
cyberx32's Avatar
Just the transmission, and the pedals. The transmission should bolt right up to the engine........but you do need a couple of more parts
kairus
05-08-2012 01:45 PM
TheOne
07-29-2008 05:28 PM
daillest
12-10-2007 01:22 PM
davster
09-28-2007 10:23 AM
sully
08-20-2006 09:23 PM
Quick Reply: Auto tranny performance
