Automatic Transmission Fluid
Old 04-18-2010, 05:53 AM
Jamber2008's Avatar
Default Automatic Transmission Fluid
Hello everyone I am new here. I have a question and that is I just purchased a 2003 Honda Civic LX and the previous owner said he never changed the transmission fluid. It has 130,000 miles on it and there is no problems with the transmission but the fluid is brown and burnt smelling it needs to be changed but should I just leave it? I have read that it might cause more damage changing it than just leaving it.
Old 04-18-2010, 07:24 AM
I dont know much about AT trans, but if you are worried about it, why not go to a Honda dealership and talk to them about it?
Old 04-18-2010, 01:48 PM
david13's Avatar
I have the 04 but only 35k miles. I just replaced, or drained and refilled mine. Just under 3 or 4 quarts.
I used Honda atf.
See what they say at service. Probably, change it.
The dealer can do a flush, if they have a flush machine. Ask them. That is where they don't just drain it, they run fluid thru' it to get all the old fluid out.
dc
Old 04-18-2010, 05:00 PM
The key is don't use generic fluid. Use Honda spec preferably direct from a dealer. I don't think flushing is a good idea compared to just drain and refill, drive a few hundred miles then drain and refill again, until the fluid looks reasonably new. If you do want to flush, have only a Honda dealer do it because other places will have generic fluid in their machine.
DeanHensler
14
06-14-2017 06:44 PM
pippo
06-16-2014 12:08 PM
mikeybson
05-02-2010 07:24 PM
enigma34
05-13-2009 06:41 PM
atikovi
04-19-2009 10:23 PM
Quick Reply: Automatic Transmission Fluid
