Automatic transmission oil change
Hi,
I知 about to change oil in my Civic (2010, LX) and I知 not sure if should I change not only oil but also filter. If yes, is it (http://www.partstrain.com/store/deta...EC0440382.html) or should I buy other?
That looks like a generic add-on filter. On older models anyway, the OEM filter was deep inside the transmission and requires removing the transmission from the car and taking it apart to replace. Thus the PM is merely to drain and refill the fluid.
The 2010 civic has a transmission filter but is a pretty big pain to get at. Honda does not recommend an interval for replacing it. I would just keep the transmission fluid clean by doing a drain and fill every 30,000 miles. If its been a while since the last drain and fill then you can do multiple drain/fills back to back (I would wait at least a day in between so the fluid is thoroughly mixed).
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
STREETFIGHTER50
03-16-2008 08:08 AM
