Better MPG Help
Better MPG Help
I've had a 2000 Civic EX coupe for a while now and I've recently come into some money so I can know fix it up a bit. I'm looking to get as much out of it, gas wise, as I can. I've changed the spark plugs and wires and keep the air filter pretty clean. The tires are basically brand new and I've been driving it like a grandpa. I've heard that a cold air intake and muffler will give me a little bit more MPG. I've also considered a full blown tune up and timing belt change since its got 136,000 miles. Is there anything else I can do that won't drain my wallet? ANY suggestions are helpful.
Belt change is a good idea, especially if you don't know when it was last changed.
As for gas mileage - short ram intake and a different muffler can help your gas mileage. The tube of the short ram intake <sri> doesn't have to be fancy. Just make sure you get a good filter. When it comes to the muffler - i'm weird. I like to relocate the muffler. I don't like it being at the end of the car. I put it in the middle. This has always made a better tone in my cars, and kept my cars from making that ricer loud scream tone. I also put the same input and output on the muffler. FK having a larger exit size.
And for better gas mileage all around - drive nice. Leave gaps between you and other cars, stay off the brakes as much as possible, keep your tires properly inflated, and use cruise control all that you can < if you have it lol >
thats slightly vauge..
sri: Short ram intake: the tube is usually larger than stock, it reaches into the corner of the engine bay to get the coolest air possible.. better than stock
Ram Intake: Longer tube, extends down into the wheelwell behind the bumper, gets colder air
heres the thing tho, ram intakes are prone to picking up water on rainy days or driving thru a puddle. they also dont give as good throttle responce... i prefer sri's
first person who gave an accurate response
Just get NGK V-power copper plugs and OEM NGK blue wires. D16s don't like aftermarket plugs (unless you are turbo/supercharge) and those give the best results.
Also consdier replacing your fuel filter, if you don't know when that happened last.
